OK, i have done a ton of research on this and cannot resolve the issue. I have a 2004 Wrangler with JVC head and the sub in the center console. The sub was blown so am trying to replace. However, nothing is coming from it when I hook it up.
The PO put the head in and I have pulled it to check the wiring. The blue/white wire goes to the lime green wire in the jeep harness behind the dash. What I don't get is where this harness of wire goes and how it interconnects with sub harness and the four other speakers. From everything I can tell, it is hooked up fine. The only thing I can think is the factory amp is blown.
If you have any guidance or insight I would appreciate it.
