My 2004 unlimited with automatic will just stop running when idling at a stop light. It is just like you turned it off with the key. It starts right up after stopping. Any ideas on what it could be?
Administrator
If you put it in other "gears" beside having it in D does it stop? N for example?
Throwing any codes? Happening at idle could be a dirty IAC
No codes were seen and not sure if it would stall in neutral or park. So far on drive.
Knows a couple things...
What is IAC ?
Idle air controller which is what provides all of the engine's air when you're not stepping on the gas pedal. The IAC is mounted onto the passenger-side of the throttle body. If it's dirty enough it can prevent the engine from idling without keeping the gas pedal pressed down a tad.
A weak/nearly dead battery like if you had to jump start the engine lately can also cause it to die at idle.
