So this topic has lots of discussion but I can't find my issue in any of them. My stock rear locker doesn't work reliably but there are no other symptoms. The lights on the dash work correctly. I push it down once and the light for the rear blinks for a second then goes solid. Push the switch down a 2nd time and the front does the same thing. The fronts work perfect all the time. The pumps seem to work correctly. When I activate the rear locker the pump turns on for a second or two and then shuts off. I removed the hose from the pump and it ran until i covered the nipple with my finger. I then removed the line from the diff and the same thing. The only thing I notice is once in a while I hear a blurp from the pump and that happens even when I block the nozzle at the pump. Now this is like every minute or 2 and only for a split second. Is it possible the pump is bad and that is causing my issue or can this be more involved inside the gears. How would I test the pump to see if its the issue? I've heard the rear diff lockers can have issues on these dana 44's. Any thoughts would be appriciated.
Thanks,
Thank you for the suggestions. I'll get this thing up on jack stands and check to see if that's the issue. I hope it's that simple.
I opened the cover and could see that bladder was filling with air when activation the pumps but was at an angle so I poked around with a flat head screw driver just to see if I could even out the bladder and was able to but didn't think it made a difference. I put new oil in and went wheeling last Saturday. I told everyone I was only running with front lockers and then because I can't help myself I attempted about a 15' almost cliff in the snow and mud. Well I didn't make it up and neither did anyone else for that matter but my rear lockers were working.
I guess the point is to poke around a bit before just replacing. Now having said that if they fail again (which I am assuming they will) then I am going to replace but until then I will keep on keeping on.
