They say you can’t judge a book but the cover, and this Jeep is no exception. Professionally built by Diamond off road Customs. This Jeep handles perfectly on and off road. 77k miles on the 6 cylinder engine and 6 speed standard transmission (Jeep is a daily driver so mileage will change). Just serviced, inspected and registered.
Features:
· Atlas 2 transfer case 4:1
· Wheel base stretch - about 3 inches
· Dana 44 front and rear axles with 4:10 gears
· Alloy shafts
· Independent front and real air lockers
· Upper and lower JKS adjustable control arms front and rear
· Modified lower control arm mounts to reduce angle and improve geometry
· JKS sway bar quick disconnects
· 3 inch suspension lift
· Ranch adjustable shocks
· 2 inch body lift
· Diamond Off Road Customs flat belly plate
· Diamond Off Road Customs front and rear differential protection
· Genright stretch rock rails (go from wheel well to wheel well)
· Genright sport/roll cage
· Electronic hand throttle control (no cable)
· 16 inch aluminum wheels
· 36 inch I-rock tires
· Matching Spare
· Diamond Off Road Customs front/rear bumpers
· Mile Marker 9500 lbs winch
· New breaks all round with upgraded rotors in front
· Additional armor and modifications not listed here
This is truly a unique Jeep that drives like a Jeep should, whether doing 70mph on the highway or tackling a 5 rated trail. Also comes with embroidered neoprene seat covers.
Asking $18,500
High Plains Beast
Very nice rig! Sorry if I missed it but where are you located? I know someone looking for this exact setup.
GLWS!
