I picked up a soft top with frame & some extras last month for <$400 on eBay.
The top is from a 2007 JKU. I have a 2013 JKU. Everything seemed to match up fine & I can't complain. But...
I'm a bit confused, I see items like a soft top boot that will work for 2007-2009, but not above.
It makes me think that I might have bigger issues to worry about.
Any tips/hints/suggestions about the situation would be appreciated.
I doubt you have bigger issues. The boot design probably stopped at '09 because of the interior change in '10. There is no issue with the soft top itself. As long as you have all of the '07 hardware.
The interior trim changed in late '10. It takes up a lot more real estate around the edges.
Bob K.
Thanks for the info Bob. I'm familiar w/the interior changes, but wasn't certain how this would affect the boot.
I looked the boot (Rampage 960435) up on several different sites... Shows 07-09 on one, 10-14 on another... I'm guessing I should be good. And it is Amazon, so if it doesn't fit, it won't be an issue to return.
The deal on the soft top was too good to pass up, especially since it was everything + extras for <$400. Glad I have less to worry about than it would seem.
Thanks!
