problem with jeep started when im having trouble putting gas into tank k
like theres something blocking the flow so the pump clicks off then i started having trouble starting jeep it would eventually start but may stall a few times and now the latest problem is when the jeep is off the fuel pump is still running and wearing down my battery i would think that it has to do with my pump but what is it
Fuel Pump Relay ?????? Might check it....see if the contacts are stuck..?
The gas tank fill problem has been hashed over on the JK Forum quite a bit, seems like the gas tanks or the fill vents had a problem and some were under warrantee and were replaced to fix the problem...
Good luck... "BH"
