The battery went completely dead in my manual 2008 wrangler. It will not crank when the key is turned, only a click. I am able to crank it by pulling out the starter relay and bridging the connections. The problem seems to be somewhere after the ignition switch. Any point towards the right direction would be greatly appreciated. I also tried to start it in 4wheel low with the same results.
Do you have a scanner like jscan? If you have a decent scanner you can plug in and see live data in the tipm and WCM that will help in troubleshooting. I can walk you trough if you have one.
Thank you, but I do not. I have a mechanic down the road a bit who can look at it Monday, but I was hoping maybe I could stumble across a simple fix here. I think I’ve eliminated any of the problems I could handle myself, but that doesn’t mean I didn’t overlook something small, or misdiagnosis something.
