1 - 13 of 13 Posts
Jeep has 25K miles on it, but as I bought it used, warranty is gone. So, I am looking at shocks, and also have a leveling kit in mind, just not right now. So my question is, will this affect which shocks I buy? I don't really rock crawl, but I do a fair amount of Jeepin' over rough and rocky terrain. Shop wanted $ 260 for 2 Sensa Trac shocks installed, seems a bit high to me, and I think given my weekend driving conditions, I want a little more aggressive shock.
If you want to stick with Monroe I would get the "Reflex". They are firmer and designed for SUV's/trucks. Other good shock choices are Rancho and Bilstein.
If you are just leveling your Jeep the shock size you buy will be the same as OEM I believe. Install them yourself. It is not hard and you will save some money.
You can find Rubicon take off shocks on Craigslist for very little $$. I paid $50 for a full set of brand new Rubi shocks which are made by Bilstein for Jeep.
The install is pretty easy.
I plan on installing them myself, only thing I haven't done before is any kind of lift or leveling. Thanks for the replies.
I put in the Teraflex 1" pucks in the front only to get level. They are less than $20 bucks each and require no other modifications to install. And no better time to put them in than when you have the front apart to do the shocks.
Vendor
Check out our 2" SPORT system.
And save some money.
But if you want to do a "level" down the road most shocks were for 0-2". There are always some exceptions though.
Rancho Suspension: SPRING PROMOTION
Nope. ;)
I have the Rancho 9000's and love them. Easy to adjust and way better than my stock Sport shocks. I did the Teraflex 2" leveling kit for $150 and installed it myself in 3 hours. Looks alot better and the shocks made a ton of difference. I don't rock crawl either, just lots of desert and mountain roads.
Went back to where I thought I had pulled that data from and can't reproduce it... So, I know you would be much more informed than I.
Discussion Starter · #11 ·
I do want to level, and I am pretty sure I will be sticking with stock wheels and tires, it is my DD. Fairly certain I will get the Rancho 9000 shocks, just not sure about swapping springs, although my bumper and winch has increased the sag a bit. I really appreciate all of the inputs!
Dave
Discussion Starter · #13 ·
Anything other than the kit needed? I will be running the stock Rubi wheels and tires. Had to make sure I had the right part number for a 2dr, Amazon lists the 4dr part number against the 2dr.
1 - 13 of 13 Posts
