21 - 40 of 50 Posts
Words? Young? The **** is your deal dude?? I'm 40 if that's young to you and I was trying to be polite with my last response to you, but I see from your last two responses you get off on being a dick to people who are polite to you. Well you can **** off with your gay grey/green jeeps and your improper LS install I'm out of this BS thread!
Discussion Starter #22
Improper install, that's ****ing hilarious... if you had paid attention in first place then you would of known this was a JK build, and you would also know the TJ was gray.
These are two reasons why you were replied to as you were..clueless is very popular these days and thats you
As for improper install I've done more with LS motors then you have so please make more of a fool of yourself by answering why cause I'll sit waiting to hear stupidity from you
Discussion Starter #23
Switched to Ls2 car intake and added a set of vette covers. The word Corvette will be filled in and a decal made that says Wrangler in the Corvette font
Discussion Starter #24
With the trans crossmember slid back as far as it is, that left us with clearance issues with stock fuel tank...we picked up a 2dr fuel tank which allows plenty of room for the exhaust now and trans crossmembe
Discussion Starter #25
Got around to welding a Vband to driverside manifold, now time to start on the Y pipe, which will be dual 2.5" into a single 4" merge
Discussion Starter #26
Started with a few bends off the manifolds for the exhaust
The trimming of upper control arm mount on pass side sure gave plenty of room for exhaust
Discussion Starter #27
Started on the Y pipe, made use of the tubing from the turbo exhaust
Ran exhaust behind trans crossmember instead of being in front so I had better access to trans pan
Discussion Starter #30
Made some progress on freshening up the Ls2
Crank polished
Light hone on cylinders
New cam bearings
New main bearings
Tapped the DOD ports for 1/8npt so cap plugs can be installed
Main bearing clearances are 0.00175 - 0.00190
Discussion Starter #31
Got the shortblock together
Cam...211/230 562/558 122.5
Oil pump is the meilings 10296
Used a improved racing oil pick up clamp
Using the solid timing chain dampener
And all 8 DOD ports are plugged
Discussion Starter #32
Wife and I made some good progress
We got all the valves and heads cleaned
Relapped the valves
New valve seals
Trickflow 600" springs
She torqued the heads down along with rockers
Next up is pay bodyshop a visit for the painted covers
Discussion Starter #33
Groot's new heart all dressed up
Had the covers and intake color matched to the body, added powdercoated coil brackets
And picked up a mobil 1 factory oil cap
Waiting on the fuel rail covers to be painted
Discussion Starter #35
Made alot of progress today,
The Ls2 is landed in its resting place
Switched to a 2012-2018 battery tray
Used the jeeps heater core hoses
Was able reuse the volant air box
Next up is PS lines, AC hoses made, upper and lower rad hoses.
After that start tackling the wiring
The vette covers arent painted yet, which are missing
Discussion Starter #36
In these pics you can see the accessory layout and clearances
Also can see how the Ls3 manifolds fit
Discussion Starter #38
Few more pics of the covers that were modded and new decals made
Discussion Starter #39
Got the rad hoses done, ended up using a 360* swivel housing to be able to tie to rad for lower hose since jeep rad points up
Upper hose was simple, just wish was able to be one piece vs sectioned
I also started playing with AC lines, reworked the on line to tie into condenser little cleaner, and tweaked the high pressure compressor line to route over to pass side where it will splice into a Silverado line and tie into compressor
When done will wrap the AC lines in power braid to help make them disappear
Discussion Starter #40
Seems as the AC system will be fairly easy, I was able to save the fittings after removing the hoses from the jeep lines and Silverado lines
Gonna order up some 5/8" AC hose and 13/32 AC hose and some crimps to tie them together
The jeeps low pressure switch threaded onto the silverados low pressure port
21 - 40 of 50 Posts
