My 2010 Rubicon Unlimited wont start. I got to work turned the Jeep off when i took the key out of the ignition it stared beeping like it does when you leave light on or anything like that but nothing was on. locked the door went into work after work the remote to unlock the doors wouldn't work so i used the key setting off the alarm i wouldn't start it lights up but it wont start and it keeps dinging I unhooked the harness going to the horn so i could see whats wrong with it it honking. when you turn the key all lights come on the throttle switch clicks but that's it the battery has 13.5V I tried giving the started a tap i pulled the IOD fuse for 30 sec i have also hooked up the code reader to it and got code PO882 witch as far as i can see mean the jeep thinks its not in park so i tried putting it in nut rel and nothing I'm out of ideas if anyone has any I have no clue what to try now.
Change battery in key. Happened to wifes jorney.
