Wrangler Forum banner
Ive noticed recently that my wiper fluid isnt spraying how it should...it kind of trickles out..any ideas of what it could be?
Check your lines for leaks and make sure they're all attached properly. The nozzle probably is clogged.
I had the same issue on my 10 a few months ago. Adjacent the reservoir is the small pump motor. It pulls straight up, inside I had an algae build up. I cleaned it out, and let the whole reservoir drain. I then took a hose and sprayed it into the reservoir cleaning it out, pushed the small motor back down, refilled with fluid and was GTG. Hope this helps, good luck.
