After looking online for a good month or so, looks like I finally found a good deal on a close out 2011. What would be a good price for this 2011 JKU..? This will be my first jeep, so i'm still learning.. Tips..?
Thanks..
This is the window sticker $27,905 MSRP.
Options 24-C
4-Wheel Disc Brakes
6 Speakers
ABS brakes
AM/FM radio
Air conditioning
Brake assist
CD player
Cloth Bucket Seats
Driver door bin
Driver vanity mirror
Dual front impact airbags
Electronic Stability Control
Front Bucket Seats
Front Center Armrest
Front anti-roll bar
Front fog lights
Integrated roll-over protection
Low tire pressure warning
MP3 decoder
Normal Duty Suspension
Occupant sensing airbag
Outside temperature display
Passenger door bin
Passenger vanity mirror
Power steering
Radio: Media Center 130 CD/MP3
Rear anti-roll bar
Speed control
Split folding rear seat
Steering wheel mounted audio controls
Tachometer
Tilt steering wheel
Traction control
Trip computer
Variably intermittent wipers
↑ to top
Features
ENTERTAINMENT FEATURES
CD player
MP3 decoder
AM/FM radio
SEATS AND TRIM
Front seats: bucket
Front center armrest
Rear seats: split-bench
Max seating capacity: 5
WARRANTY
Corrosion perforation warranty: 60 months/100,000miles
Basic warranty: 36 months/36,000miles
Roadside assistance coverage: 36 months/36,000miles
Powertrain warranty: 60 months/100,000miles
CONVENIENCE FEATURES
Front beverage holders
Passenger door bin
Speed control
Rear beverage holders
Driver door bin
Air conditioning
Tilt steering wheel
BODY EXTERIOR
Skid plates
LIGHTING, VISIBILITY AND INSTRUMENTATION
Front fog lights
Trip computer
Compass
Tachometer
SAFETY AND SECURITY
Brake assist
Ignition disable
Electronic stability
ABS brakes
4 wheel disc brakes
Traction control
↑ to top
Tech Specs
POWERTRAIN
Engine liters: 3.8
Torque: 237 lb.-ft. @ 4,000RPM
Cylinder configuration: V-6
Fuel economy highway: 19mpg
Sequential multi-point fuel injection
Number of valves: 12
Recommended fuel: regular unleaded
Transmission: 4 speed automatic
Horsepower: 202hp @ 5,200RPM
Fuel tank capacity: 22.5gal.
Fuel economy city: 15mpg
Drive type: four-wheel
Engine location: front
SUSPENSION/HANDLING
Rear anti-roll bar
Power steering
Front anti-roll bar
Tires: all-terrain
SPECS AND DIMENSIONS
Exterior body width: 1,877mm (73.9")
Curb weight: 1,924kg (4,242lbs)
Payload: 518kg (1,142lbs)
GVWR: 2,404kg (5,300lbs)
Compression ratio: 9.60 to 1
Rear hiproom: 1,440mm (56.7")
Engine horsepower: 202hp @ 5,200RPM
Rear legroom: 945mm (37.2")
Passenger volume: 2,914L (102.9 cu.ft.)
Rear headroom: 1,026mm (40.4")
Exterior height: 1,801mm (70.9")
Wheelbase: 2,946mm (116.0")
Engine bore x stroke: 96.0mm x 87.0mm (3.78" x 3.43")
Turning radius: 6.3m (20.6')6.3 '
Front hiproom: 1,412mm (55.6")
Air Pollution Score (AP): 5
Front headroom: 1,049mm (41.3")
Towing capacity: 1,588kg (3,500lbs)
Exterior length: 4,684mm (184.4")
Greenhouse Gas Score (GG): 1
Engine displacement: 3.8 L
Engine torque: 237 lb.-ft. @ 4,000RPM
Interior maximum cargo volume: 2,458 L (87 cu.ft.)
Front legroom: 1,041mm (41.0")
Rear shoulder room: 1,443mm (56.8")
Front shoulder room: 1,417mm (55.8")
Interior cargo volume: 1,314 L (46 cu.ft.)
OFF-ROAD CAPABILITY
Approach angle: 41 deg
Ground clearance (min): 221mm (8.7")
Departure angle: 38 deg
Ramp breakover angle: 18 deg
Ground clearance (max): 229mm (9.0")
OPTIONAL EQUIPMENT
Customer Preferred Package 24C
4-Speed Automatic Transmission $ 825
Hill Descent Control
3.73 Rear Axle Ratio
Automatic Transmission Skid Bar
Black Freedom Top 3-Piece Hard Top $ 735
Freedom Top 3-Piece Modular Hard Top
Freedom Panel Storage Bag
Rear Window Defroster
Rear Window Wiper / Washer
Tinted Rear Quarter and Liftgate Windows
DESTINATION CHARGE $ 800
no retreat, no surrender
If that's the *price*, and you can get them a bit more off of it, plus maybe change out the tires/wheels (I did)... I'd have to give it serious consideration. I bought my '11 before the 12's, knowing they were coming, and have no regrets. I'm assuming this is a 4 door since you wrote JKU, not JK..... and it's good it has the 3.73's. jmo That's a good chunk of change between that and the 12. On the other hand, if you have a family of 4 that will load up frequent roads such as the 70 going through the Eisenhower Tunnel (long steep unrelenting grade)...
