1 - 20 of 21 Posts
Traded in my 2008 JKU (manual) for a 2011 JKU Rubicon (auto).
Bought from dealer
Previous owner added:
- 35 inch Mickey Thompson tires
- Moto Metal Wheels
- 2-3 inch?(unsure) Procomp susp. lift
- Angry front grill (I am not a fan of the angry front grill look. I have since swapped this out for oem front grill)
- Winch (the winch is stuck in freespool mode. need to fix this).
Discussion Starter #8
blacked out the chrome wheels with wheel paint.
The previous owner put on moto metal chrome skull wheels.
These are not the wheels i would have chosen... but they will do for now.
blacked out chrome wheels with wheel paint.
I am happy with the result.
Steps:
1. clean wheels with soap and water or wheel cleaner
2. rinse & wipe wheels dry
3. put plastic bag behind wheel to protect brakes and other parts from getting paint on them
4. put painters tape on parts of wheel you do not want to paint
5. use sandpaper and sand down the parts of the wheel you wish to paint
6. wipe any sand paper residue from wheel
7. apply 2 coats of wheel paint
8. appy 1 coat of wheel gloss
9. remove painters tape from wheel and garbage bags from behind wheel
10. sit back and marvel at your blacked out wheels :)
Discussion Starter #12
Barricade HD Tire Carrier for OEM Tire Mount (07-18 Jeep Wrangler JK)
steps:
1. remove spare tire & carrier
2. remove oem vent in tailgate
3. put new supplied vent on tailgate
4. place support under tailgate (i used wood shims)
5. unbolt/remove oem hinges from tailgate
6. wipe area clean (note bare metal under hinges will not be painted)
7. paint bare metal under hinges to prevent future rust issues
8. bolt on new hinges to tub (keep bolts loose for now)
9. put tailgate reinforcement plate into hinges
10. put hinge pins into place
11. tighten down hinges on tub
12. bolt on tailgate reinforcement plate to tailgate
13. ensure tailgate opens and closes without issue
14. put spare tire carrier back on
15. tighten all remaining bolts
16. put spare tire back on
Discussion Starter #13
Barricade HD Tire Carrier for OEM Tire Mount (07-18 Jeep Wrangler JK) cont...
Discussion Starter #14
Metalcloak Chromoly Dog-Legged Tie Rod Installed and Alignment done.
The MetalCloak Chromoly Dog-Legged Tie Rod comes complete with a heavy duty adjustable steering stabilizer mount bracket for aftermarket steering stabilizers and installs into the factory location.
Tubular 1.375”OD .375” wall ID 4130 Chromoly CDS
1-Ton Forged Heat Treated Off Set Dog Leg Rod Ends
OE Taper Pin for Exact Fitment
Design Limits Misalignment to Control Tie Rod Flop
Sealed with Durable Rubber Grease Boots
Gold Zinc Chromate Finish
Adjustable While Installed
* Man this tie rod is super beefy... looks like it was forged by Dwarven blacksmiths in Asgard. lol :)
Discussion Starter #17
Added the RockSport Steering Stabilizer Kit, JK Wrangler to go with the new Metalcloak tie rod
this kit contains the MetalCloak Steering Stabilizer Axle Side Relocation Mount that places the steering stabilizer up and out of harms way from where the factory steering stabilizer was mounted originally.
Found a Rubicon 10th Anniversary Off Road Bumper FREE on Craigslist.
The bumper has been in an accident (it has a cpl dings in it) but I was able to buy a new fog light bezel for it and bolt it on to the jeep.
I still need to add a fog light to the drivers side bezel and will prob. re-paint the bumper with bed liner but so far i am happy with it.
Discussion Starter #19
Mopar Front Off-Road Bumper (07-18 Jeep Wrangler JK) Removed from my 2011 jku Rubicon 'Grips'. Time lapse video:
Rubicon 10th Anniversary Off Road Bumper for 07-18 Jeep Wrangler JK Installation. Timelapse video:
Wow lucky!
1 - 20 of 21 Posts
