1 - 18 of 18 Posts
Price: $39,500 (Kelley Blue Book is $38,391 without the Mods)
MW3 Special Edition #297 of 3,500
Color: Bright Silver Metallic / Black Interior
Miles: 17,307 Clean Carfax
Never Off-Road, daily driver, non-smoker, loaded and no stories.
Mods:
Upgraded AEV JK Premium Front Bumper w/ Bullbar & Skidplate
AEV JK Winch Mount
Dealer Installed 2” Stage 2 Lift Kit with Fox Racing 2.0 Perf. Series IFP Shocks
Quadratec Ultimate Floor Liners Front / Rear / Rear Cargo
Mopar 2” Receiver Jeep Hitch Plug
Drake Offroad Black Billet Aluminum Hood Hold Downs
Drake Offroad Black Billet Aluminum Grille Inserts
Professionally Installed PIAA 520 Xtreme White ATP Lights (135 watt)
Professionally Installed Warn 9.5 cti-s Winch w/ 100’ Spydura Synthetic Rope (never used)
Mopar Black Entry 4 Door Sill Kit w/ Jeep Logo
Safari Straps Warrior Cage Extended
Safari Straps Front & Rear Grab Handles
Safari Straps Headrest Handles
PIAA 15” Super Silicone Wiper Blades
Professionally Installed CoastalETech Lockpick with Front & Rear Cameras
Hothead 4 Door Headliner Kit w/ Rear Side Window Panels (Full Kit)
Professionally Installed 20% Front Tinted Windows (Factory Match)
K & N Air Filter
Mopar Soft Top Boot w/ Window Bags
Smittybilt G.E.A.R. Tailgate Cover w/ PAL/MOLLE Storage Bags
Stubby Antenna
Mopar 5 Piece Factory Wheel Lock Kit
PIAA H13 Xtreme White Plus Headlamp Bulbs
Heininger 2” Hitch Extension
Order Package 24R
3.6 Liter V6 24-Valve VVT Engine w/ 5 Speed Automatic
Hill Descent Control & Tip Start
Dana 44 Heavy Duty Front & Rear Axles
Electronic Sway Bar Disconnect
4:1 Rock-Trac® Part-Time 4WD System
Tru-Lok® Front and Rear Axles
Electronic Stability Control
Traction Control
Factory Remote Start
Uconnect® Voice Command with Bluetooth®
Media Center 430N CD/DVD/MP3/HDD/NAVIGATION
Factory Heated Front Seats
A.C. w/ Auto Temp Control
Factory Side Airbag Option
Factory Freedom 3-piece Hardtop w/ panel bag
Factory Black Sunrider Soft top
Max Tow Package (never towed, for carrying bike rack)
Factory Rock Rails
Power Dome Hood
BFG Mud Terrains & Black Wheels
New Takeoffs (never used) – Radio Antenna, Factory Hood Hold Downs, Front & Rear MW3 Tire Tread Mats, MW3 Badges, Trail Rated Badge, MW3 Carpet Rear Cargo Mat, MW3 Spare Tire Cover, Factory Lug Nuts, Clothing Hook Straps
Full Dealer Receipts for Scheduled Maintenance
Documented 5 Tire Rotation & Oil Changes
Local Purchase Only - Valparaiso, IN (Northwest IN)
No parting out, sorry.
PM with questions and more pictures, I will get back to you within 24 hours.
Thanks,
Mike
Question bump! Kinda off topic, hope it's cool! What was your mpg with the 4.10 gear ratio? Also do you know if the receiver hitch is 2"? Thanks
Sorry I answered one of my questions about the receiver hitch haha sorry just mpg question
Mpg
Hi Yellow Fox,
Jeep advertises 16 city / 20 highway on the 5-speed auto. I never really cared about the mpg, if I did I would be driving something different.
So, I had to go out and look, it keeps the average and it was at 15.1 mpg. I have never reset it and I drive more city than highway. I am not sure how accurate that is, I have read that guys have measured between fill ups and figured higher and lower numbers than what the average on the info screen says. Some people have even reported lower mpg at first and then a steady increase to what Jeep puts on the sticker.
Keep in mind my Jeep has a 2" Fox lift, the AEV premium bumper with bar and skid plate along with a Warn 9.5 cti-s winch and plate so that weight and higher front rake will affect the mpg. The way you drive and where you drive also effects it. I may be missing other reasons but I think those are the basics. Hope this helps!
Regards,
Mike
Thanks I just wanted to know if the gears made a difference thanks
This might be a stupid question, but did you lift it without adding bigger tires and wheels? I assume those are stock what you have on now. Do you know how big the tire size you are able to go up? Thanks.
Discussion Starter · #15 ·
The tires and wheels are stock. Directly from the Fox / Mopar Lift kit:
Wheel and Tire Recommendations:
Tire Diameter:
Up to 35"
Tire Width: No greater than 12.5"
NOTE: Tires wider than 10.5" may require wheels with dimensions as follows:
Wheel Diameter: No less than 17"
Wheel Width: 8"- 9". Do not use less than an 8.5" wide wheel with a 12.5" wide tire.
Wheel Back Spacing: 3.25" to 4.75". As backspacing dimension decreases, track width and stability increase.
I hope this answers your question.
1 - 18 of 18 Posts
