2012 jk manual with 35" tires and 3.21 gears. does anyone have this set and like it?
does anyone out there have this set up and like it? i just bought my rims and tires today and hate the thought of regearing but will if i have to.
they arent on it yet. everything is ordered and will be put on in the spring. is it gonna suck so bad that i won't wanna drive it?
I've got 33's and 3.73 gears, and 6th gear is really only useful for 65+mph on level ground. Any little hill slower than that, and you will be downshifting. I'd think that it would take a lot of clutch slipping to get going as well with 35's and 3.21's
As much as I hate to be Debbie Downer...
You're in central PA where there are hills, lots of hills. You will find yourself downshifting - A LOT if you keep the 3.21 gearing.
With a manual and 35" tires, you might be better off with 4.10 or maybe even 5.13 so that when you tire of your 35"s (yeah, you saw what I did there) you can step right into 37"s and not really notice a difference.
Another route is to look for someone who is getting rid of their F/R Rubicon axles and work something out with them. Do that and you end up with lockers out of the deal in addition to the better gearing.
Some other things to consider:
Get a tuner so you can calibrate your speedo and odometer for the larger tires.
Trim the pinch seam by your rear tires (or slice your tires open on the first speed bump you hit.)
You may need to look at wheel adapters if your backspacing isn't adequate. You will want to keep the rubber from rubbing on your steering components.
Lifting the Jeep - since you didn't mention a lift, I wasn't sure if you had already planned on doing so. A 35" tire won't leave you much room for articulation.
If you have a 2dr, you will want to be mindful of how tall you want to go
Anything more than 3" on a JK means you will eventually encounter issues with your driveshafts.
Extend your brake lines or add relo clips
bumpstops to keep you from bottoming out the shocks and bending them.
Upgrade your shocks - new ride height means the stockers will no longer fit. They may work for a day or two, but I would'nt trust them any further than I could throw them
i want a 2.5" lift. my backspacing is adequate. will i still need to trim the pinch seam? from what i have been reading i was thinking 5.13 gearing. is a tuner hard to use? cause if i can screw it up i will. how much am i looking at for a regear? i was reading $1500 give or take a few hundred
