1 - 9 of 9 Posts
Hi , i know this is an old subject but just curios if anyone find any fix to the JK blowing colder air on driver side ?
It is either a bad blend door or clogged heater core. Fix is to replace the blend unit. And if heater core can try flushing it forward and back to clear any sediment clogging it.
I already flush the heatercore, and same problem ... Where is lovated exactly that blanding door ? Can i fix it myself ?
Discussion Starter #7
The one behind glovebox compartment is blend dor actuator... I change it and nothing... Another question i have guys , if thouse two pipes (crome pipes ) behind glovebox are flaming hot it means is no issue with the heatcore am I correct?
1 - 9 of 9 Posts
