Jeep: 2012 JKUR 6sp with under 23K miles on it. the problem im experiencing is the rear locker light flashes at me in normal driving conditions when letting off the throttle with the clutch still engaged. The light will flash a few times than stop. If I engage the clutch the light never appears, therefor when the rear diff is under pressure while deceleration the light comes on. The light never comes on when I accelerate only on deceleration??? The jeep has under 3000 miles on the new yukon gears but this problem just started. Thoughts??:drinks:
There could be a problem with the solenoid not completely disengaging the locker. Actually, the solenoid engages the locker and when the lockers are electronically disengaged springs release and the locker is then disengaged. That's probably the best place to start.
