I noticed that behind the grill on the bottom, there is a strip of metal about 2" wide that has some surface rust. I want to sand and repaint it to stop the rust. My question is are the Crown Push Pins reusable? If they are not, I need to order new ones before I continue.
Thanks
Grumpy Old Guy
Yes, they are meant to be reused... however, order some anyway. I always break one or two of them off when taking them out.
Grumpy Old Guy
Yep. Work them from both sides several times if you are interested in saving them. If the whole pin comes out of the seat, no worry, they still work.
I've removed my grill about 20 times and my push pins are still perfect.
Take a tiny electronics flat head screw driver, pull the center Pin straight up so its almost out. If you do pull it out, no worries...
Then the whole thing will come right out. There is no unscrewing motion needed.
