2012 JKU - Quick Oil Change Question, Please Help!
1598 9
In the middle of doing my first ever oil change thanks to the guidance of the WF, and I have a question- please pardon my ignorance.
I don't see a gasket on the oil drain plug- just looks like it was on there without one. Is this normal? Should I be fishing through the drained oil for it? The bucket it's draining into has a grate / filter that should have caught it, but I'm not seeing it there.
I don't think that I should be relying on the drain plug without the rubber seal / gasket, so just wanted to get the collective's advice.
Thanks
1 - 10 of 10 Posts
Thanks for the quick reply, everyone. Breathing easier :)
The Bad Guy
In the olds days they had a plastic washer. If anything ever happened to it you could make a new one out of a plastic coffee can lid. The good ol' days....
No gasket on the filter on the '12. It's a cartridge. There is a rubber o-ring on the cap. You get a new one with every filter.
Success! Oil change completed. No leaks, though it did get a tad messy with the oil shooting out a couple feet upon removing the drain plug. Laid some cardboard down as a precaution so no biggie. Replaced the O-ring as well.
Next up- swapping out the headlight bulbs.
1 - 10 of 10 Posts
