Can I fit a set of stock 2012 rubicon wheels under my 2012 sport with no issues? can I ever go a little taller without a lift? Photos would be appreciated.
Thanks
The 2012 Sport with aluminum wheels are the exact same wheel as the Rubicon, just painted a different color. Obviously you would still need to upgrade to the BFG M/T for the same look.
Boxerjeep12 said:
Can I go a little taller? Is your jk set up like that? looks like you have no lift on yours.
Well yes, it is a Rubicon.
I do believe the Moabs and 32" BF's can be optioned on a sport.
The Rubi and Sahara do not have a lift from the factory. Gas shocks and maybe stiffer springs. The the height difference is in the tire/wheel combo.
Putting them on a sport the ride hight should be the same.
33 tires will fit on a stock Jk but aftermarket wheels with less backspacing will be needed.
Discussion Starter #6
How much more lift will the rubi tires and wheels give to my sport, it currently has the 16" steelies? Thanks for you help
