1 - 10 of 10 Posts
check for the built date on the door panel (drivers side) post if possible...
I want to say this is the coolant lines rattle
built on 11/11 .it have some issues. have a sound like rough or any vibration on engine, not in center console. its if the engine sounds inside the wrangler. also when starting at cold in the morning sounds like a discharge lifters. but are two different sounds. the first sound is when accelerate in a slope and also the temperature start to high a little up to the middle of the gauge. is the first wrangler that i buy new and have some issues.
That's the coolant line fix, sound like engine problem, but its not. Try that fix, if doesn't work, head to dealer
1 - 10 of 10 Posts
