I purchased the above and am going to put 18 inch rims on 33" atz's. I would also like to give the jeep a 3 inch lift. Is it safe to do this with a the brand new jeep and not jeopardize the the performance of the jeep? Basically will it screw anything up?
Thnx
You should be fine. Lift wise you'll have enough clearance. But putting 33 inch tires on 18 inch wheel is going to cost nearly double than the same tire on 15 inch wheels in some cases. But yes, you should be fine. Gearing wise it may be a bit sluggish. Do you know what gears you have and is it a manual or auto transmission?
