Do you know the torque specks on the oil cooler? I am changing mine now.Covered by warranty at least, right? As it's part of powertrain, by virtue of being bolted to top of the motor. Indeed a worrisome thing when considering being in the hinterlands during a failure.
Welcome to the Forum, from Cave Creek AZ.Do you know the torque specks on the oil cooler? I am changing mine now.
Believe it is 18ft-lbs IIRC, but would encourage you to confirm that. It does not take much. Part of why I change my own oil so that I can make sure some careless person doesn’t inadvertently go “gorilla tight” on that fragile filterDo you know the torque specks on the oil cooler? I am changing mine now.
I assume you are replacing the entire oil cooler & filter housing assembly. If so, torque is 106 in-lbs in this sequence:Do you know the torque specks on the oil cooler? I am changing mine now.
Aye, ye dirty bastard! another farkle to spend me hard earned coin on.... Thanks, bought, be here tomorrow.lol.I use this:
Amazon.com: DEPSTECH Wireless Endoscope, IP67 Waterproof WiFi Borescope Inspection 2.0 Megapixels HD Snake Camera for Android and iOS Smartphone, iPhone, Samsung, Tablet -Black(11.5FT): Automotive
Buy DEPSTECH Wireless Endoscope, IP67 Waterproof WiFi Borescope Inspection 2.0 Megapixels HD Snake Camera for Android and iOS Smartphone, iPhone, Samsung, Tablet -Black(11.5FT): Borescopes - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Why is this piece called an oil cooler? I don’t get it.A plastic oil cooler filled with 200+deg oil bolted to the hot engine valley and useing smashed rubber O rings to seal from leaks at full engine heat and oil PSI. What could go wrong with that. Just add the nightmare of a job to replace it. The part has been revised about 6 times now. What,, the 4th try couldn't get it right?? It's so stupid it's really LOLOLOL.
This part bolts to the engine in the valley and has a coolant line going to it to cool the oil. It is also the oil filter housing. It is simple and saves space under the hood, until it fails. Then it is a real pain.Why is this piece called an oil cooler? I don’t get it.
Also, I would love to see the aftermarket come out with a remote oil filter relocation kit so we could eliminate this inferior pice.
Thanks, I figured this was the case but for the life of me I couldn’t remember seeing any lines going into it back when mine failed and I can’t look at mine since I’ve loaned my Jeep to my brother for the last 8 months due to him being out of work.This part bolts to the engine in the valley and has a coolant line going to it to cool the oil. It is also the oil filter housing. It is simple and saves space under the hood, until it fails. Then it is a real pain.
You're a good dude. My wife doesn't even get to drive the Jeep and I am certainly not loaning it to my brother.I can’t look at mine since I’ve loaned my Jeep to my brother for the last 8 months due to him being out of work.
LMFAO!You're a good dude. My wife doesn't even get to drive the Jeep and I am certainly not loaning it to my brother.![]()
Ha, yeah well the only thing that makes this hard is he lost his job due to the Wuhan virus and I’m sure he blames Trump more than China for everything that‘s happened to him given his liberal leanings.You're a good dude. My wife doesn't even get to drive the Jeep and I am certainly not loaning it to my brother.![]()
Avoiding a non Jeep related rant. He would never even sit in my Wrangler. That's the end of that.Ha, yeah well the only thing that makes this hard is he lost his job due to the Wuhan virus and I’m sure he blames Trump more than China for everything that‘s happened to him given his liberal leanings.
Had to replace mine on my 14 JKU at 66K miles in December of 2018. The check engine light never came on and boy was it leaking.At my work we have 12 Wranglers from 2016 and up, most of them over 160k km, I can say this oil cooler is a common problem, we replaced three of them and one for a Caravan with over 200k km. It is very dangerous because the oil leaks fast, luckily the check engine light comes on right away with an oil pressure code, so I would say anytime you have check engine light ON take a quick look under the car. I have a friend with a Chrysler 300 with same problem. When you replace it is good to replace also the small cooler hose which is connected to it, we used only OEM parts, I would stay away from AM because is a lot of work to replace it and is risky.
