1 - 10 of 10 Posts
Hey guys I have been reading and trying to figure out this issue, and I have not found out why.
I use my brand new procal to set my tpms at 28, it honks twice turn off then on but light never goes away.
I release vin and air up to 40 psi and it still does not go away. My tpms reads psi and was working fine until I tried to adjust.
I disconnected the battery for an hr, drove around town for hours and no help. I went to dealer waited over an hr and no one even came to help and I had to leave.
I was wondering if anyone has any feedback? I have read countless threads and have tried
Removing battery
Driving for 20+ mins highway speeds
Airing down and up
Releasing vin on procal
Only setting procal to disable gets rid of light, but check TPM still shows
Any help is greatly appreciated!
I did try that several times! What yr is your JK?
2012! Maybe try setting something else that won't affect the usability of the Jeep to see if the device is faulty? Like daytime running lights - test one of them. If that doesn't work either I'd assume you have a faulty unit with switch broken or something.
I have a 2016 and had no issues with this. Maybe contact Superchips directly. Maybe there is a glitch in your Procal.
I have the AEV procal. I bought it at dealer, but their customer service is horrible. Will go in tomorrow again.
Oh right. Superchips is the flashcal. Sorry, I was confused. Having dealt with Superchips in the past, they have great customer service. Sorry you are going through this. I was happy enough with superchips that I have ordered another one for my 06 XK.
Also the other functions work. And if I disable the TPMS the light goes off, but evic still says check tpm
I put new rims and tires on mine and have no sensors in them. When I turn it to "offroad" mode, I get no indication that they were ever there. I would think the Procal would do the same.
Yes I am able to completely disable it, but I wanted to lower it to 28psi.
When i disable and remove battery for 30 mins i dont get any messages or lights. But id like to have some sort of indicator, if not I will leave off as is!
1 - 10 of 10 Posts
