1 - 10 of 10 Posts
Jeep started leaking coolant recently and I've traced the leak to the thermostat housing which I will replace over the weekend. Any thoughts/suggestions as to which replacement part I use? I see Duralast, Murray, and Gates brands at parts stores near me. Or could see if the dealer has OEM in stock, but at probably double the price.
I would go with OEM
Second choice Behr-Mahle (if available)
Gates IDK anything made of rubber is good (hoses, belts) Tstat is probably made in china.
I would suggest before installing "boil" it, to check if opening temperature is correct.
Retired Moderator
Oem...
Reactions: strawman
Doesn't someone make a super high performance billet CNC replacement?
Reactions: strawman
Good point. On a side note, I wrote about this to Mishimoto in their product suggestion/request section. If there is more interest, they may build one. I also suggested an all metal oil cooler/filter housing assembly.
Oem is good and includes everything. It is improved over the 2014 housing as well.
Reactions: strawman
I also recommend the boil test. I’ve done this with all my thermostats in the past. My 2015 JK was running hot and the thermostat would barely crack open. Once it cooled off it was not properly closing. So I replaced it. Make sure you purge all the air out when replaced
1 - 10 of 10 Posts
