I have a 2014 Jeep Rubicon-X, outside of warranty (97K miles). Short version...since the 70K point when warranty expired I have had to replace the thermostat and housing twice, and the heater core has taken a dump and streaming hot water from under the dash to the passenger side floorboard. This is to the point where I have to completely refill the radiator and overflow tank every 30-40 miles before the coolant levels drop to the points where temps are hitting over 225*F. With each thermostat replacement the coolant system was flushed and there was sandy sludge in the coolant overflow tank. Each of those repairs, all in, ran ~$800. The quote on the heater core replacement is just shy of $2K at the local Good Year shop (only place I have taken it so far). The service manager at the shop I went to let me know that there is a class action lawsuit against Jeep relating to manufacturing not getting all of the cutting/polishing aggregate flushed out of the cooling system during the build. I did some Google searches and it sounds like this has been underway for like 3+ years now. Essentially what the lawsuit states is that Jeep failed to clean this sand out of the engine, which under normal operation wears out parts and causes a sludge build-up in the heater core. This causes a variety of issues including thermostat and heater core failure. The tell-tale sign is a build up of sandy sludge in the coolant overflow tank - EVEN AFTER a flush and cleaning out this tank. This describes my situation exactly.
My question is this: Has anyone tried and successfully had a Jeep dealership admit and address this problem outside of warranty? My local dealership in Columbia, SC is impossible to deal with. They told me on three occasions (while still under warrant) that the Jeep spiking to 245*F "was normal for a Wrangler" and refused to do anything about it. If anyone has been able to get Jeep to do this, how? What are the magic words? Who is the right person to talk to? I spent 3 hours and 10 minutes being bounced around the Jeep 800 Customer Support line before they put me on hold and hung up.
Any advice would be greatly appreciated...not a good time (is it ever?) to face a $2K maintenance issue.
