My 2014 Unlimited just started getting bad radio reception. The satelite radio works fine-very clear. The radio has static on all stations. No work has been done recently on the vehicle.
Most likely radio itself as if it was antenna AM would also be marginal at best
Does the radio have a local distant setting for FM is so you may have switched it to local which decreases FM reception to filter out weaker signal stations
You might find this interesting
