So I have been having a very annoying issue with P0304.
I have swapped plugs, coil packs, injectors, have new cams, lifters & rockers.
I have done a leak down and compression test and everything is normal.
If I start the engine and put it in gear quickly, it doesn't throw the code.
It only seems to throw the code when it idles at start up.
I noticed the other day, it's idling around 650 - never above 700.
What is the idle supposed to be and does anybody have any other input of what to look for?
Thanks in advance!
“An EGR valve that is stuck open, a leaking Intake Manifold Gasket, a defective Mass Air Flow Sensor, a weak or failing fuel pump, or a plugged fuel filter are some of the many causes for a lean misfire.”
Since it only happens at cold idle, a lean misfire sounds like a possibility. Above are some possible causes.
(Pentastar has no EGR and no MAF)
Do you have access to a good scan tool? Does your scanner show how many misfires? Do you feel it missing, or is it just a code? And then is it always and only P0304, so cylinder 4 misfire?
Also you say it happens after startup, though you have to mean RE-start-up with warm engine. Otherwise if the engine is running cold, then it should be running in open-loop and no misfire code should be set (at least according to the pre-canbus vehicles that I have been working on).
