does anyone make a HD rear transmission mount for JK? The stock mount seems way too light/flexible. I can grab the rear DL and move the trans./transfer case by hand quite a bit. It's this weak mount and drivetrain movement that makes the stick want to slap you in the face. I know they all do it.....because they all have the same mount, but it's not right. Any suggestions? Also is there a programmer that improves the throttle?
How tall is your shifter that it's slapping you in the face? Trans mounts need to have some play in them so the case doesn't absorb the shock of bumps and driving torque.
There may be some companies that make a polyurethane mount. That would be a bit more firm than the rubber mount, but I'd wait till your warranty ran out to change that. If you changed it and something happened to your drivetrain, your claim could be denied.
From 07 to 15 they all move (jump) as a result of having a direct connection, unlike most other vehicles.
