did you ever get the wobble fixed? about to order my rk 2.5 flex system and im nervous for the same results
Yes, I finally did. It turned out to be Discount Tires fault. I will never understand how, but they screwed up the balance 4 times throughout the phases of my troubleshooting!!
I finally got a competent assistant manager who told me "they were all out 4oz or more except 1 at 2.5" & I about flipped! I was never going to get my wasted money back or the time I spent in 115+ AZ heat, so had to settle for the $112 refund (since I bought them somewhere else) & "near cost" on my next set.
If you do get wobble, check in this order of biggest bang for the least amount of bucks:
1. Get your tires re-balanced & have them write down the before & after (I will ALWAYS do this from now on!). Note: the more sidewall the less roadforce is worth it - eg: it's for cars
2. Check trackbar torque
3. Driveway ball joint test, better with 2 ppl
4. Check draglink & tie rod ends while doing the BJ test
5. Alignment - castor should be 4.5 to 5.5 & toe-in at 1/8th, camber doesn't cause wobble
6. Consider the stabilizer. Note: if the root cause isn't fixed, a new 1 will just mask it
7. Bent parts? If everything was fine before the lift, then you're running out of options & may have to recheck things
Find a decent installer & make sure they'll align it. Also ask up front how they'll help if you get wobble. Call reputable 4x4 shops. I've got a shop near me that'll figure out you're wobble for only $35, just wish I knew that before I threw my money away.
