2015 Complete wiring diagram
91911 Views 27 Replies 18 Participants Last post by  atti.gulfbreeze
I've been looking to hook up the last wire in my keyless entry install to the horn honk. Got this wiring diagram from another automotive electronics forum and thought it could be useful here.
I asked for the diagram to my '15 JK Sport, but it could be the same for other similar years.
12 Volts red + battery or underhood fuse box
Second 12 Volts lt. blue/red (10A) + ignition switch, black 5 pin plug, pin 5
Starter yellow/gray (for starter kill only) + starter or underhood fuse box, blue 26 pin plug, pin 8
Second Starter purple/brown (use interface mod or Tech Doc 1084) - 180 ohms ignition switch, black 5 pin plug, pin 2
Ignition pink/white + ignition switch, black 5 pin plug, pin 3
Second Ignition N/A
Third Ignition N/A
Accessory same as second starter - 560 ohms
Second Accessory N/A
Third Accessory N/A
Keysense same as second starter -8.5K ohms
Data Bus N/A
Can Bus High white/black (CAN C bus) data SKREEM around ignition switch, black 8 pin plug, pin 6
The CAN IHS bus high is white/gray at the instrument cluster, brown 20 pin plug, pin 16.
Can Bus Low white/lt. blue (CAN C bus) data SKREEM around ignition switch, black 8 pin plug, pin 7
The CAN IHS bus low is white/orange at the instrument cluster, brown 20 pin plug, pin 15.
Can Bus Sw N/A
Power Lock purple/lt. green -1000 ohms driver kick, door harness, black 14 pin plug, pin 5
Power Unlock same as power lock - 180 ohms
Lock Motor tan/white 5 wire driver kick, door harness, black 14 pin plug, pin 8
Driver Unlock Motor tan/lt. green 5 wire driver kick, door harness, black 14 pin plug, pin 1
Passenger Unlock Motor tan/brown 5 wire passenger kick, door harness, black 14 pin plug, pin 8
Parking Lights (-) (LIN bus)
Parking Lights (+) white/orange (L), white/purple (R) + passenger kick, harness to rear
Hazards white/dk. blue - hazard switch, black 8 pin plug, pin 1
Turn Signal (Left) white/lt. green (F); white/dk. green (R) + turn signal light (F); passenger kick, harness to rear (R)
Turn Signal (Right) white/tan (F); white/yellow (R) + turn signal light (F); passenger kick, harness to rear (R)
Headlight white/dk. blue (L), white/orange (R) + headlights or underhood fuse box, green 26 pin plug, pins 3 and 11
AutoLights N/A
Reverse Light white/gray + passenger kick, harness to rear
Left Front Door Trigger purple - driver kick, door harness, black 14 pin plug, pin 4
Right Front Door Trigger purple/white - passenger kick, door harness, blk 14 pin plg, pin4
Left Rear Door Trigger purple/gray - passenger kick, harness to rear
Right Rear Door Trigger purple/yellow - passenger kick, harness to rear
Dome Supervision yellow/white + underdash light or passenger kick, harness to rear
Trunk/Hatch Pin purple/orange - passenger kick, harness to rear
Rear Glass Pin N/A
Hood Pin purple/lt. blue - hood switch or underhood fuse box, gray 16 pin plug, pin 3
Trunk/Hatch Release N/A
Trunk Release Motor lt. green/white (unlock only) 5 wire passenger kick, harness to rear
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm see disarm no unlock
Disarm No Unlock Sentry Key, ignition, and keysense
Trunk Alarm Shunt N/A
Tachometer bn/yl, bn/dk bu, bn/lt bu, bn/tn, bn/og, or bn/pu ac any fuel injector, black 2 pin plug, pin 2
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal yellow/orange - clutch switch under hood, black 3 pin plug, pin 2
May need to interrupt dk. green/orange, pin 1 of the clutch switch during remote start to avoid check engine light.
Fuel Pump dk. blue/orange + underhood fuse box, brown 40 pin plug, pin 10
Rear Defroster dk. blue/white + latched passenger kick, harness to rear
Mirror Defroster same as rear defroster
Left Front Heated Seat (LIN bus)
Right Front Heated Seat (LIN bus)
Speed Sense (wheel speed sensor)
Brake Wire white/tan + brake switch, gray 6 pin plug, pin 6
Parking Brake dk. green/white - parking brake switch, black 1 pin plug, pin 1
Horn Trigger gray/yellow + horn or underhood fuse box, green 26 pin plug, pin 18
Wipers brown/lt. blue (L), brown/orange (H) + wiper mtr or underhood fuse box, brown 40 pin plug, pins 12 and 11
Left Front Window (Up/Down) lt. blue - white A front power window switch, black 14 pin plug, pins 14 and 13
Right Front Window (Up/Down) brown/lt. blue - purple/white A front power window switch, black 14 pin plug, pins 7 and 3
Left Rear Window (Up/Down) orange/white - orange/gray A front power window switch, black 14 pin plug, pins 8 and 9
Right Rear Window (Up/Down) orange/lt. blue - orange/dk. blue A front power window switch, black 14 pin plug, pins 1 and 2
Sun Roof (Open/Close) N/A
Sun Roof (Limit/Close) N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Radio 12V yellow/red + radio, gray 22 pin plug, pin 1
Radio Ground black - radio, gray 22 pin plug, pin 12
Radio Ignition (CAN IHS bus)
Radio Illumination (CAN IHS bus)
Factory Amp Turn-on (CAN IHS bus)
Power Antenna N/A
Left Front Speaker (+/-) gray/purple - gray/yellow +,- radio, gray 22 pin plug, pins 21 and 22
On models with amplifier, the speaker wires are gray/purple - gray/yellow at the amplifier under driver dash, black 16 pin plug, pins 8 and 16. The tweeter wires are gray/orange - gray/yellow at the amplifier, white 22 pin plug, pins 20 and 9.
Right Front Speaker (+/-) dk. green/purple - dk. green/yellow +,- radio, gray 22 pin plug, pins 19 and 20
On models with amplifier, the speaker wires are dk. green/purple - dk. green/yellow at the amplifier under driver dash, black 16 pin plug, pins 7 and 15. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, white 22 pin plug, pins 19 and 8.
Left Rear Speaker (+/-) gray/lt. green - gray/dk. green +,- radio, gray 22 pin plug, pins 8 and 9
On models with amplifier, the speaker wires are gray/lt. green - gray/dk. green at the amplifier under driver dash, black 16 pin plug, pins 13 and 5.
Right Rear Speaker (+/-) dk. green/lt. green - dk. green/gray +,- radio, gray 22 pin plug, pins 10 and 11
On models with amplifier, the speaker wires are dk. green/lt. green - dk. green/gray at the amplifier under driver dash, black 16 pin plug, pins 4 and 12.
Center Channel (+/-) N/A
Subwoofer (+/-) gry/brn - dk grn/brn (1); gry/wht - dk grn/wht (2) +,- amplifier under driver dash, blk 16 pin plug, pins 14 and 6; 3 and 11
Aux. Audio Input Left (+/-) dk. green/orange - dk. green (hands free audio) +,- radio, gray 10 pin plug, pins 1 and 6
Aux. Audio Input Right (+/-) dk. green/yellow - dk. green (hands free audio) +,- radio, gray 10 pin plug, pins 2 and 6
RSE Video (+/-) N/A
RSE Audio Left (+/-) N/A
RSE Audio Right (+/-) N/A
Satellite Radio 12 Volts N/A
Satellite Radio Ground N/A
Satellite Radio Ignition N/A
Satellite Radio Antenna N/A
Satellite Audio Left (+/-) N/A
Satellite Audio Right (+/-) N/A
Item Size Depth Location
Headunit double DIN center of dash
Left Front Speaker 6.5 left front dash
Left Front Tweeter 0.75 left front dash
Right Front Speaker 6.5 right front dash
Right Front Tweeter 0.75 right front dash
Left Rear Speaker 6.5 left rear roof
Left Rear Tweeter N/A
Right Rear Speaker 6.5 right rear roof
Right Rear Tweeter N/A
Center Channel N/A
Subwoofer 8 right rear quarter panel
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner (built into radio)
1 - 20 of 28 Posts
I, actually, would like to actually see (get) a true, complete, wiring diagram for our JK's.
Someone have a link to such?
Ask and you will receive. The following link requires you to enter the year, model, and engine near the top of the page to view the wiring diagrams...
TechAuthority - Vehicle Wiring Diagrams
WOW! Do you know how long I have been searching for something like this??? Several weeks and never once has this resource popped up! Thank you!!
help
did you happen to download the wire diagrams they locked that website down
Locked down how? I seem to have good access with the link.
I just went to it with no problems. I just sent that site to a buddy of mine that has a RAM truck.
Thanks for the great resource Off Pavement!
See ya on the Trail!!!
It worked for me just now from work and my company tends to block a lot of websites with their firewall. No problem when I randomly looked at several wiring diagrams.
Has anyone tried the wiring diagram connection recently? Looks like the URL leads to a 'demo' server, that I'm guessing is available some of the time, but not sure if it has gone away completely or if I should keep trying.
Thanks
Here is the complete URL:
https://techauthorityonlinedemo.extra.chrysler.com/service/repair/wiring/view/classic.htm
SRVE0255E: A WebGroup/Virtual Host to handle /service/repair/wiring/view/classic.htm has not been defined.
SRVE0255E: A WebGroup/Virtual Host to handle techauthorityonlinedemo.extra.chrysler.com:443 has not been defined.
IBM WebSphere Application Server
WillyD, thanks for testing. I wondered if they had finally taken down their 'demo' server. Looks like they move the information under their 'Dealer Connect' portal. Not sure if anyone has the ability to post to a Google Drive or DropBox.
Or if anyone sees that it's back up please post to this thread.
I have a drop box but used only once. Do you have the file and needing a server? I sent you a PM
WillyD, no I don't have the file, was hoping someone else had downloaded it while it was available and could share/pass on.
Thanks for the offer
still getting the error when trying the link. Is that site down for good?
I think too many people were accessing the site who were not supposed to be using it and it raised a red flag and they took it down.
Did anyone download and keep a copy of the wiring diagram? If so I would like it.
Thanks
Sorry to bring back an old thread but does anyone have the full diagram? The web site seems to be down now.
You can view online wiring diagrams for any year Wrangler at the link below.
BBB Industries
Reactions: 1
BBB Industries
Thanks alot!
1 - 20 of 28 Posts
