More of a pictorial really. Sorry not a better write up. Mainly dealing with the switch pod. I used everyone elses write up to actually remove the seats and install the heating elements.
I have been trying like heck to put heated seats in my Jeep and use the factory switches. There is a thread somewhere that mentions a guy in FL that can re-program the computer if you want to add all of the factory parts. IIRC, it was a $ hundo or a little over? Too rich for my blood. (Actually I want auto lights too and thought about having him program both but still too much $ for me). I saw a video of a guy adding a micro switch between the OEM switch cover and the PCB board behind it. Looked promising so I studied the circuit forums for a while and designed a momentary clicky switch layout using micro relays and a debouncer but it quickly became too complex and I was still not sure I could get a momentary switch to do Off-low-hi-off again. I know our switch panel has a PCB sandwiched behind the switch covers. I assumed (HA HA) that my lowly little sport was not using all of that PCB and it was just there for Jeeps with more options than mine.
So long story short, I hacked off the ends of the PCB behind the blank switch covers, gutted the switch holes, glued the blank switch covers on the heated seat switches, and then glued the switches in the now gutted holes. Everything worked as planned. See pics:
Our switch panel is pretty neat design actually. All of the switch covers not being used are already hinged and ready to be used but the sides are left long and won't allow the switch to move. Just requires a little trimming and they actuate as Jeep designed them too. The pics should show the slide and rocker hinge mechanism of the switches.
Took out the PCB measured and hacked off the ends. Then I gutted the two end switch slots to make room for the aftermarket switches. I did not use the factory hinge parts, I used the aftermarket switches to provide the rocking action.
I pulled the switch covers off of the aftermarket switches and glued them to the underside of the OEM Jeep blanks. I forgot to take a pick before starting so I included a generic of the switches that came with my kit. I also wanted a way for the LED to show when turned on so after the glue set I drilled through the LED holes in the aftermarket switches through the OEM blanks. I broke a tong or tine or whatever off of a clear plastic acrylic dinner fork. I sanded it down and rounded it until it snuggly pierced the aftermarket switch hole and stuck out of the front of the OEM switch blank. I then cut off the excess flush with the switch cover.
Reassembled the switch covers with the switch body and placed them in the switch panel and clamped them up with some paint sticks. Made sure they were square and plumb and glued the switches in the jeep switch panel. In that last pic you can see the new LED hole and clear fork thingy.
To be continued....
To be continued....
