been looking but not found anything.Is there a way to remove the headrest. I remove the spring so it lays back but with my top that don't work.I wold like to remove to see better, but also be able to put it back in.
If your headrest fold down with the seat they are like my 2012 and I literally just took them out. Start by taking the headrest off, there is a little spring clip that will allow it to slide off. We took the seat covers off, so unclip at the bottom and unzip on the bottom side. 60 side seat has a zipper on each side. Pull up the foam and on the front of the seat there is a bracket, 5/16th bolt holds it in place. Take them off then use a screwdriver to pop loose the little clips. Slide the bracket down and unhook the cable. That's it.
