carpet on drivers floor frequently very wet. this happens when there has been no rain for several days so seal leak not in play.
any suggestions appreciated.
Retired Moderator
Thread Moved.
I've read about AC lines being clogged under the dash somewhere.
The carpet is very thick. Yours might be so saturated that it stays wet. Mine did that and I finally just pulled it and have run without ever since. You may just want to pull it and see if water shows back up.
The hose that carries windshield washer fluid to the rear glass sprayer runs through the firewall and behind driver's kick panel. It may be leaking.
