1 - 1 of 1 Posts
ExtremeTerrain.com Sponsoring Vendor
2018 Wrangler JL Spy Shots + 2016 JK 4" Lift & Rampage Top! - ExtremeTerrain.com!
On the premiere monthly episode of Throttle Out, watch the latest Wrangler news, builds and products happening at ExtremeTerrain!
We kick of this episode of Throttle Out with a 2015 2-Door JK that gets a suspension & lift upgrade to get this thing performing out on the trails.
First off, we opted to put large lift on this JK, and decided on the Rough Country 4" Lift Kit with Shocks. This lift kit is on the larger side for a 2-door Wrangler but drives smooth and does not have a ton of body roll when out on the roads.
Next up on the install are two suspension modifications. The Rough Country Front Control Arm Geometry Correction Brackets and Rough Country Dual Steering Stabilizer were first on the list to install. The control arm geometry brackets were a no brainer when lifting this Wrangler up 4 inches. These brackets will help to correct for pinion and castor. The Rough Country steering stabilizer will help to dampen some of the road shock, preventing it from traveling up through the steering wheel.
After this JK build take a closer look at some of the most popular Rampage parts on site at ExtremeTerrain.com such as the Rampage Frameless TrailView Soft Top. This is a fastback soft top that allows you to disassemble the peices and transforming it into a safari bikini top.
In the last segment of Throttle Out we take a look at what you expect from the brand new 2018 JL Wrangler. Check out some spy shots and as well some features that you can expect out of the newest generation of Jeep Wranglers.
To see all products and information included in this episode of Throttle Out head over Right Here!
and for the latest news and information on the 2018 JL Wrangler check out the ExtremeTerrain Blog!
Features Parts:
Rough Country 4" Lift Kit w/ shocks (2-Door)
Rampage Frameless Trailview Soft Top [/SIZE][/SIZE]
1 - 1 of 1 Posts
