2023 Order Waiting Room
102566 Views 1456 Replies 145 Participants Last post by  A300Driver
Have a 2023 on order? Discuss lead times and more in this thread
Order banks open June 15th, 2022
Production starts August 15th, 2022
New for 2023:
Highlights:
  • Standard 3.6-liter Pentastar V-6 engine delivers 285 horsepower and 260 lb.-ft. of torque, standard with ESS, and a six-speed manual transmission.
  • Wrangler’s 3.6-liter Pentastar V-6 engine is available with mild-hybrid eTorque technology and an eight-speed automatic transmission
  • 2.0-liter turbocharged inline four-cylinder engine with ESS delivers 270 horsepower and 295 lb.-ft. of torque. Standard on Sahara and available on Sport and Rubicon
  • The plug-in hybrid Wrangler 4xe features a 2.0-liter turbocharged inline four-cylinder engine integrated with two electric motors and a 400-volt battery pack, delivering 21 miles of all-electric range and 49 MPGe
  • Wrangler four-door models offer an available 3.0-liter V-6 EcoDiesel engine with ESS, rated at 260 horsepower and 442 lb.-ft. of torque. To handle the increased torque, the EcoDiesel V-6 pairs to a TorqueFlite 8HP75 eight-speed automatic transmission, calibrated for low-RPM shifts
  • Selec-Trac two-speed transfer case with full-time four-wheel drive and a 2.72:1 low-range gear ratio is available on Sport models
  • Rock-Trac 4x4 system with full-time four-wheel drive and a “4LO” ratio of 4:1 optional on Rubicon models
  • Jeep Wrangler Rubicon 392 four-door model offers a 6.4-liter V-8 HEMI engine, rated at 470 horsepower and 470 lb.-ft. of torque. To handle the increased torque, the HEMI V-8 pairs to a TorqueFlite 8HP75 eight-speed automatic transmission
  • The capable driveline of the Sport and Sahara models include the Command-Trac NV241 part-time, two-speed transfer case, which features a 2.72:1 low-range gear ratio and next-generation Dana front and rear axles. In addition, an optional Trac-Lok limited-slip rear differential provides extra torque and grip in low-traction environments, such as sand, mud or snow
  • Wrangler Sport and Sahara models offer a Selec-Trac two-speed transfer case with full-time four-wheel drive and a 2.72:1 low-range gear ratio. This full-time two-speed transfer case is intuitive and allows the driver to set it and forget it, while constantly sending power to the front and rear wheels
  • The Wrangler Rubicon model features Dana 44 front and rear heavy-duty axles, enhanced off-road rock rails and the Rock-Trac NV241 two-speed or optional full-time transfer case with a 4:1 low-range gear ratio. Wrangler Rubicon also includes electric front and rear locking differentials, a disconnecting front sway bar and 33-inch BF Goodrich KM all-terrain tires, taking Wrangler to places others simply can’t go
  • Optional Xtreme Recon Package, available on Willys four-door, Rubicon four-door and Rubicon 392 models, includes LT315/70R17C (35-inch) BF Goodrich KO2 all-terrain tires, 17-by-8-inch beadlock capable wheels, 4.56:1 axle ratio, swing gate reinforcement and 1.5-inch factory suspension lift with uniquely tuned shocks
  • Best-in-class approach angle of 47.4 degrees, departure angle of 40.4 degrees, ground clearance of 12.9 inches and water fording of 33.6 inches help the Jeep Wrangler with Xtreme Recon Package scale the toughest terrain
  • Wrangler models feature lightweight, high-strength aluminum doors, hinges, hood, fenders and windshield frame, as well as a magnesium swing gate, to help reduce weight and boost fuel economy
  • Available on Wrangler four-door models, Sky One-touch Power-Top allows occupants to open or close the Wrangler’s roof with a push of a button. The Sky One-touch Power-Top can be used at speeds up to 60 mph
  • The flip-top Sunrider for Hardtop, available on all Wrangler models, offers a front-row soft-top that quickly and easily flips back for an enhanced open-air driving experience
  • New for the 2023 model year, Jeep Wrangler features a new Wrangler decal featuring an American flag on each front fender. In addition to honoring the Jeep brand's military heritage, this new decal also pays homage to the American workers who manufacture this iconic vehicle
  • Dual-Door Group, with base or premium uppers, includes both full and half doors. Full-steel production doors are installed on the Wrangler while matching body-color half doors are conveniently packaged within the vehicle. Engineered, tested and backed by the factory, the new half-door option enhances the Jeep Wrangler driving experience with production styling, security and occupant protection. With lower window ledges, new half doors provide improved visibility while maneuvering on and off road
  • Factory-backed, doors-off mirror kit for Wrangler is specifically engineered and tested to original-equipment standards, providing a production-equivalent field of view with minimal vibration. Each mirror in the kit attaches to a cowl-end cap bolt and the upper door hinge. In addition, an innovative, custom thumb wheel-nut-clamp is used as an attachment point to the door flange. Mounting brackets are finished with an anti-corrosion undercoat and durable black powder-coat finish. Mirrors include a built-in breakaway feature that prevents damage while in tight spaces on the road or trail
  • Wrangler models offer the TrailCam forward-facing off-road camera with the 8.4-inch touchscreen, accessible through the available Off-road Pages
  • Off-Road Plus, standard on Wrangler Rubicon, adjusts throttle, transmission shift points and traction control
  • Jeep Wrangler’s signature features include iconic round headlamps, seven-slot keystone grille, trapezoid wheel flares, removable doors, exposed hinges with the Torx tool-bit size stamped into it, a fold-down windshield and innovative removable tops that allow the Wrangler to retain the brand’s iconic appearance and function
  • Fourth-generation Uconnect system includes Apple CarPlay, Android Auto and the choice of a 7.0- or 8.4-inch touchscreen with pinch-and-zoom capability
  • Standard electronic stability control (ESC), electronic roll mitigation, trailer-sway control, Hill-start Assist and brake traction control are among more than 75 available safety and security features
Model Lineup
For 2023, the Wrangler lineup consists of five models:
  • Sport
  • Sport S
  • Sahara (four-door only)
  • Rubicon
  • Rubicon 392 (four-door only)
Jeep Wrangler 4xe details are included in 4xe specific documents. Please reference Jeep Wrangler 4xe newsroom on the media site.
Available Exterior Colors:
  • Black
  • Bright White
  • Earl (NEW)
  • Firecracker Red
  • Granite Crystal
  • High Velocity
  • Hydro Blue
  • Reign (NEW, limited edition)
  • Sarge Green
  • Silver Zynith
  • Sting Gray
Available Interior Colors:
  • Black
  • Black/Dark Saddle
  • Heritage Tan
Reactions: 1
1 - 20 of 1457 Posts
I should correct one thing in the above excellent post: The 2023 Jeep lineup is not just five models, but nine:
1) Sport
2) Willys Sport
3) Sport S
4) Willys
5) Rubicon
6) Sahara
7) Sport RHD
8) High Altitude
9) Rubicon 392
(As show on the 2023 Jeep Build & Price website: Build & Price Your New Jeep® SUV or Truck Today! | Jeep®
  • Love
Reactions: 3
Jeep sent me an email with my order number yesterday! LOL, now today its order tracking says it isn’t in their system but I checked and dealer shows it ordered and confirmed so not really worried.
Sport S - getting the extra half doors which is exciting.
  • Love
Reactions: 4
Loved our '16 with half doors!
Currently there are 5 models of Wranglers (excluding 4XE)
  • Sport
  • Sport S
  • Sahara
  • Rubicon
  • Rubicon 392
Everything else is a "package" based off one of those models.
Reactions: 1
2 door Willys Sport 6 speed manual in Earl. Took a chance on the color since I’ve only seen pictures of the concept Gladiator from 2 years ago.
Ordered 7/21, no VIN yet. Was told 10-12 weeks but I’m anticipating a lot longer than that.
Reactions: 4
Pat, I hope that my ordering experience is not duplicated for you, but I also ordered a 2-door Willys Sport, with manual transmission, back in January, and it was just built in the second half of July, just over six months later. And I still don't have it yet!
Good news is if it takes forever I can just transition straight to the half doors in spring, lol. 12 weeks no big deal for me and gets my JK through the peak of the often dusty and dirty hunting season. If it shows up by Thanksgiving that will be a pleasant surprise.
Reactions: 1
I am planning on doing the same! My first (and only so far) had half doors and I loved the look
Reactions: 1
Ordered my first Jeep, 2023 Sport S on 8/11 with an estimated delivery of 8-12 weeks per the dealer. On 8/16, the Jeep Vehicle Order Tracking site listed it as "Order Confirmed". I also have the VIN from the dealer but it is not shown on the website yet. So far so good. Now the long wait starts.
Reactions: 2
I sure hope not! That is a long wait.
Reactions: 1
Just ordered my 2 door Willys Sport w/ a manual transmission in Reign with the Black and Tan interior. Wasn’t going to add any other options but decided on the towing kit because adding the trailer wiring is annoying 🤣🤣
No idea how long this is going to take, but I’m happy to be getting my 4th wrangler. Had two YJs in my youth, and bought a JK in 2013. Can’t wait to be out of this Kia and back in a Jeep!
Reactions: 3
Hey all,
I was quoted 8 weeks for a 2023 Willys, I have read through most of the 2022 order threads, some people still having not received their Jeeps in May when ordered in January.
Just figured I should be ready for disappointment!
Thanks
Reactions: 1
Ordered a 2-door Sport S soft top in Reign on 15 July. Got a VIN on 3 August but the tracker still only shows "Order Confirmed" so I'm guessing I'm still in C status. When I ordered in July, the dealer said 3-4 months was typical. But I know there are some who ordered after me who are already in production. There seems to be a wide variety of wait times depending on the specifics of your order.
Automotive parking light Land vehicle Tire Vehicle Automotive side marker light
  • Love
Reactions: 4
I was told 3-4 months by the dealer when I ordered mine on 15 July. I know, as you've pointed out that some folks have waited much longer, but I also know that some 2023's already have build sheets assigned.
Reactions: 1
KME, I have seen a number of orders that were delivered only six or seven weeks after placing the order, then there are others, such as mine, that have taken or are taking seven or eight months. It is hard to tell you what to expect! But from my observations, the fully-loaded Jeeps (i.e., Rubicons and Saharas) have been taking significantly less time to deliver than many or most of the Sport, Willys Sport and Willys models, which have been tending to take the longest.
  • Sad
Reactions: 2
You mean these greedy deliver the most expensive ones first?
Reactions: 1
It sure looks that way to me!
  • Sad
Reactions: 1
Update to Jeep Vehicle Order Tracking System for my order. Order was Confirmed on 8/11. It now shows Scheduled on 8/18 with the VIN added too. Took one week. Any ideas how long can I expect for next step, In Production?
Realistically, I'd expect at least 14 weeks from the order date. Occasionally one will arrive sooner than that, and as Chugiakguy can attest to, some take a hell of a lot longer. But, on average, 14-16 weeks is realistic for most.
Reactions: 1
We sold our 2014 Sport privately, then ordered a 2023 Sting Gray 2 Door Rubicon,
Ordered on July 21. Since I've received a VIN # and that's it. Was told 8-12 weeks.
Can't wait!!
Reactions: 2
