I'm replacing the junk weber 34 that came on my yj when I bought it a few months back. My question is: what's up with the air injection lines that weber says to hook up but are not currently on my existing carb? I've seen installs with and without then tied into the top of the air cleaner but can't find anything explaining why. The haynes book is useless in this since the stock carb is long gone. I've found multiple vacuum line schematics and they are all different. If I had done the original install I'd know. It may be useful to point out this is my first Jeep so I'm already unfamiliar with it under the hood.
All I can tell you is on the 4.2 engine the only vacuum lines you need is distributor and brake booster and fuel tank vapor line and the front axle half shaft vacuum solenoid. So I would say your best bet is if you are getting rid of the weber then go with a MC2100 or MC2150 because they are very simple and don't require any weird air tubes. And trash all the other vacuum junk and disconnect the EGR valve and plug up the ports.
I already have the new weber installed. Whoever did the original conversion did had it all tied in together. I did a nutter too since that hadn't been done. Fired right up. Little bit of a sputter in idle but screams when I stomp on the gas. Had to get creative with the throttle linkage, the factory hardware is long gone so I had nothing to mount the cable on to make the attachment to the weber linkage in the carb. Dumped the supplied linkage and did the following:
Vehicle Auto part Engine Car Fuel line
Pedal is a bit tight but works fine. Nothing a little Teflon lube in the cable jacket won't solve. Idle and timing adjustments removed most of the sputter, gonna change the plugs and and cleaner in since the old carb was running super rich. Hoping that smooths it out.
