Hi guys,
1+ year into my frame-off 250k miles TJ resto. Frame coated, new suspension/lift - chassis looks sweet.
I'm up over 200 hours now - learning as I go.
Motor on stand, disassembled, head sent out and redone.
(4 valves replaced, springs shimmed, only 5 thousandths shaved off - guy said, "that head was in great shape for 250k")
Also, inside oil pan looked very clean, no metal, very light crud build-up for about 1.5" around the drain plug.
I can still see the cross-hatching on the cylinder walls, if that means anything (will gauge them this weekend - finally got the tools)
Questions:
Every camshaft lobe is shiny new in the middle, with wear-discoloration out toward each side. A fingernail scrape reveals a very mild "roughness".
4432904
I'm leaning toward the $200 replacement. Thoughts? Is there a micrometer measurement I could take, or is the pic above clear evidence of needing replacement?
Also, it is highly probable that I mixed up 2 or 3 of the lifter positions (forgot to remove, 3 fell out as I rotated the engine on the stand - doh)
Should I buy new lifters and push rods?
Thanks!
Looks similar to the wear I had on mine (190k miles roughly) after loosing a piston skirt last year. Before stripping it down I'd decided to replace the camshaft and lifters. I went for the Melling kit off Rockauto that also included additive for use during break-in. I replaced the rods and rockers too for good measure.
Thanks guys! Ordering today...hope to get this engine back together this weekend and finally mounted to frame
Cheers
Cam doesn’t look bad but once the hardness wears off the it goes quickly. I would replace it because it simply will not last forever and you don’t want to have to disassemble again for a $200 part.
Discussion Starter #6
Thanks DCLXVI,
I have come to that conclusion too. Picking up camshaft, lifters, push rods, distributor, freeze plugs, and oil today. I hope to have the motor back together and mounted back on my jeep by the end of this weekend - for the first time in over a year.
Cheers!
