So I just put the tires on my otherwise stock JL. They don’t rub at full turn, but they do at about 3/4 turn. Any idea what that would be? I am putting a 2 1/2” lift on in a few days. Will that eliminate the rubbing? What else would I need to do to make this set up best? I do know that I need to get the computer/speedometer deal flashed.
Thanks.
2 1/2" lift will fix this if it is a good lift. With a 2 1/2" lift you could also run 35s.
