1 - 15 of 15 Posts
I have 285/70/17 on my 15 with a Teraflex leveling kit. Only problem I had is rubbing at full lock on the sway bar. For the taller 285/75 tires, is it the width or the height that causes the problem when flexing? If I went with a narrower tire that is still the same height, does that solve the flex problem?
285/75 will be taller, but both are 285 wide so you won't see much of a difference width wise. If you only have a leveling kit and no ride height increase, you'll likely rub both due to width and height running the 285/75s.
Only a slight increase in height (my 285/75/17 Falkens actually measure out at 32.75 mounted and loaded.) Rim BS will help with rubbing, or spacers.
Just thinking if I went 255/85 I'd still have a 34, but it wouldn't contact when turning. Will the 34 still contact vertically during flex?
I think your answer is in here:
https://www.wranglerforum.com/f27/largest-tire-on-stock-jk-heres-your-answer-142837.html
I've subbed to that thread for over 4 years and have read most of it. Not that you need to (or even can in a short period of time, lol.) The first few pages cover a lot of the basic questions about what fits and what rubs.
Stock rims?
I am running that size on my 09 with stock rims, 1.5" wheel spacers and a Q-tech leveling kit. No rubbing except at the fenders when I am really flexed.
Friend has those. 1 1/2 inch wheel spacer or wheels with less back space. I have 315-70-17s with 4 1/2 inch backspace and no rubs.
I ran 285/75/16s (which are the same size as 285/70/17s) on 4.75bs wheels with a TF leveling kit on my old rig. Disconnected and fully stuffed, I would make pretty significant contact with my inner fenders. My old thread (linked a couple times above) contains pics of that I believe. Bump stop extensions would have prevented that of course.
Sent from my SM-G970U1 using Tapatalk
I have a little 2" spacer lift and I recently put 285/75 tires on wheels with 4.75 backspacing. They rubbed my air dam at full lock. I had to trim the corners of the air dam somewhat.
In your case, it's width not the height..
For example, a 285/70R17 tire is shorter than the 285/75R17, but is close to the same height as the stock 255/75R17.
In most cases with stock wheels, the 285/70 will rub on the sway bar, (and sometimes on the plastic air dam behind the bumper). The same will hold true for the 285/75 which despite being taller, is the same width.
As Col Sanders says above.. Spacers or new rims..
285 70 17 and 285 75 17 are technically the same width.
Maybe some difference in lug pattern between mfg.s
the 75 is taller by 1.1 inch.
I assume when you talk of flexing you are referring to the sidewall getting wider? so yes, if you deflate the pressure the taller sidewall will flex to a wider width when severly compressed.
your wheel offset and backspace are what typically need to change so that you can run " wider" tires. without using adapters or spacers which are kinda "hokey" as a way to correct a incorrect backspace or offset. unfortunately, cost is a consideration and we sometimes need to use adapters to make the change affordable.
I agree with the people that say go to a 15 inch or 17 inch diameter wheel if you want big tires that will actually work off road. My kid wanted an appearance so we went with 20" wheels a 33 x 12.5 tire MT and a minimal spacer level/left kit.
it looks pretty cool, but is not really serious off-road functional.
1 - 15 of 15 Posts
