Read some of the threads on the benefits of 2.5" or less lifts kits. Just about every 2.5" lift talks about it.
If you still decide to with 3.5" prepare to buy other parts that are not included in the lift like driveshafts, adjustable control arms, ball joints, etc.
Your '07 has the 3.8L engine which does very poorly without the proper gearing. 35" tires are best fitted with a 5.13 gear ratio. Changing gears runs about $2K with labor.
Since you are limited on your parent's budget, be kind to them and stick with a 2.5" lift and spend the savings on gears. It will provide enough lift for 35" tires. It will make your Jeep a lot more drivable on the road.
