1 - 9 of 9 Posts
I guess I'm getting old, but for the life of me I can't find the cold fill line on the coolant overflow tank. Can somebody tip me off?
(Which is extremely lame, I was looking at my brother's 3.8L about a week ago and it's plain as day. Also that engine bay is amazingly roomy compared to the tightly-packed 3.6L... but I digress.)
Reactions: mcguirev10
you might need a flashlight to see it the first time but once you know where it is it will reach out and slap in the face.
I removed the bottle and painted the min/max marks with a permanent marker :)
Cold on mine is 1" below max, some like it in the middle.
I found for me right at min is best otherwise when I offroad it spills out making a stink and freaking me out I have a leak lol.
If you disconnect the hose you can pull it up and out so you can mark it. It just hangs on a slot joint. You won't even have to empty it.
No need to remove the over flow hose. Just lift straight up on the reservoir it has plenty of slack. I just removed my buddy's to work on his steering box.just slides in and out.
Awesome, thanks everyone.
1 - 9 of 9 Posts
