I've got a 2.5" lift and still have (and am keeping) stock flares and bumpers.
Most notably, I have the 3.8L JKU Rubicon and am looking for advice as to which of these wheel & tire combinations will leave me better engine performance?
Is there a notable weight and rolling resistance difference between these tires?
I like the "pizza" look but unsure what I gain and lose between these two sizes with respect to my 3.8L engine.
not sure what 285/75-17 you are planning on using but generally that is going to be a heavier tire and also taller. the 34x10.5-17 is most likely going to be a KO2 as not sure who else makes that size. The KO2 in that size is really pretty light. I measured one at 52lbs. I know my 285/75-17 toyos were considerably heavier and taller so based on that the 34's will be more spunky.
I switch back and forth between my Toyo 35's that are within .25" of the 285 toyos for height and a few pounds in weight and when I put the KO2's on I feel like I turbo charged my 3.6L. strange thing is mpg is identical with either set up.
Great reply, thanks. After reading about the KO2 lightness I thought my mind was made up but then with the mpg being the same I am confused all over again!
Any 3.8L engine experiences?
