1 - 20 of 33 Posts
Any one know the cheapest place to get a set of 3" lift front coils...? And how much of a hassle to get them in?
dont go with cheap. But if you want good springs for around $250 shipped. Go with BDS.
Do i have to relocate the track bar...with 3" springs?...right now i have 2.5" spacer blocks on stock springs..didnt need a relocate
You "don't". But your rear axle will be off set to one side. As it is already. There not expensive.
Guess i dont understand the mechanics of it..lol.....im looking to put the springs in the front...
Was told i could just drill a new hole to mount the track bar..about 3/4" outside stock hole...?
I've heard that to. I dont know. If your looking for just the front your fine
I got a set of Tera 3 inchers I would let go for $125 plus shipping, nice riding springs...
New BDS front springs are cheaper then that before shipping and with their no B.S. warranty.
Huh? The front axle moves over when lifted too. You can drill a new hole, but you need to weld a plate over the axle bracket to re-enforce it. Didn't I go over this with you Trav?
Discussion Starter · #18 ·
So if i do rear also...can i redrill as well?... how do i determine where the new hole goes?
Not on the rear. You need an adjustable track bar, or a track bar relocation bracket.
For the front, simply measure how far the axle is off and drill the hole that far over. But you NEED to weld a plate over the bracket first, or it will crack and or pull out.
I ran this 3 inch lift for 2 years with the front offset about an inch, no issues at all. I also have the relocation bracket for the rear......
1 - 20 of 33 Posts
