So my stock transmission pan keeps leaking. Even my friend who is a mechanic can't get it to stop (but he did slow it down a lot.) It's as good an excuse as any to replace with a deep pan. I know Skyjacker makes a stamped pan that will work, but I kind of wanted an aluminum pan. Will a Torqueflite 904 or 999 pan work? The other questions: Is there any benefit to an aluminum pan over a stamped pan? Or is it a waste of money? I've already added a trans cooler to the Jeep, it was one of the things I did to it in the first year I had it.
Pic because I can:
Knows a couple things...
I don't see any significant benefit to an aluminum pan over steel since you already have an aux cooler. I'd just get Skyjacker's deep pan and then have a 1/8" NPT steel bung welded into it so you can add a transmission ATF temperature gauge. If you go that right take care where you install the bung. A temperature sender can come too close to the driveshaft if you mount it in the wrong location.
That makes sense. Thanks for the information Jerry!
Do you know someone in Orange County that can weld 1/8" NPT steel bung
in?
