1 - 15 of 15 Posts
Is anyone running 33" tires with 2.5" OME suspension lift here? Pictures please if you do.
Will I need spacers if I do and what size will I need to clear a 33" tires.
Thanks in advance
I do. 2.5" OME + 1" BL + 1" bumpstop extensions in front, 1.5" in the rear.
You can't fit 33s on a 2.5" OME alone. You need either: A) 1" BL + 1" bumpstop extensions in front, 1.5" in rear or B) 2" bumpstop extensions.
If you have an aftermarket front track bar the bumpstop requirement will increase, because otherwise the track bar will hit the diff cover at full compression. Also, if you have the OME track bar relocation bracket installed, without at least 1.25" of rear bumpstop it will hit the tub at full compression, and the shocks will bottom out.
I do too. I have the 2 inch OME suspension, 1.25 inch body lift and a 3/4 spacer in the front. You can see my profile for the pictures. What are your plans for the axle and gearing??
i recommend 2.5'' with a 1.25'' bl
That WF guy.
Not in the sense that you are talking about. I took that pic. :cool:
So you stated...years ago. :flip: ...the lay out and lighting are crap, just saying. :flipoff: :p
You didn't mess up. You did right! Dirk is the man for TJ suspensions.
Ditto, and don't mind Mr. C...he has this tick that can only be cured by grinding parts off. :zap:
:rofl:
I know this thread is old but I though some people searching would appreciate some fresh pics.
First Picture: Jeep with 2.5 OME ultimate kit Lift from Dirk and stock Rubi tires (245/75/R16).
Second Picture: Jeep with 2.5 OME Lift and BFG A/T 33X11 tires.
Fourth, Fifth and sixth Picture: 2.5 OME Lift, BFG A/T 33's, 1.25 body lift and spacers to make the stock Rubi Rims fit.
The lift handles great, similar to stock, its a Jeep so theres always noise and bumps. Hope everyone enjoys the pics.
1 - 15 of 15 Posts
