I want to put a stock 350 motor with my ax15 tranny but i wonder if there is something to fit with the clutch slave cylinder or if i just dont do anything new with it. The slave is outside the tranny. So do i need to change all the oil clutch system?
I did a 350 conversion using the NV3550 which is similar to the ax15. I used the GM bell housing with an adapter from Novak to connect the transmission. I also used an external clutch slave cylinder set-up from Novak.
The Novak website provides a lot of technical background on what you need to know about your conversion. https://www.novak-adapt.com/knowledge/
