1 - 20 of 30 Posts
Retired Admin/Mod
Which super swamper? TSL LTB, etc.. most of then run very close the size listed. As for the lift..with the right bump stops it might work. I would however 1st upgrade your axle if you have not done so with that tire size.
was gonna say.. it takes more than just throwing on the tires to run that big of tire..
gears/shafts, the right axles.. plan it out more
I have a 4 inch RC, I put my buds spare 35 on just to take a look. No clearance at all. And I agree, I would look at a gear change and maybe axles, depending on what you are planing on doing with it.
It's a daily driver. I'm not going rock crawling in it. I've talked to numerous lift shops and all of them say it'll be fine as it is.
what lift shops? that may be the problem..
why 36 iroks for a dd? no reason to spend money on nice tires if your not gonna use em
Retired Admin/Mod
....yes have half the county voted for change and look how that worked out... anyway... 36's on a daily driver.. not fun. You need to think about more than fitment. So its a street jeep great. Have you tried to stop with 36's swampers in the rain with the stock brakes? What about your steering? Lots to think about. Also with that size tire your stock gears are going to make the jeep be and feel slow.
I think he's going for the "look" and couldn't care less about anything else. Let him run them he'll find out the rest the hard way.
I ran 36s on 4 inches of lift total, stock gearing and axles. beat the hell out of it on and offroad, to this day no issues have come up :)
can someone explain how you can get away with 36's and stock gears?? I have stock 3.73's and 33" claws, and I feel like the Jeep has an anchor tied to it. 5th gear is useless unless I am going over 60 mph and the road is not perfectly flat. I can't imagine how crappy it would be with 36's!!... Any jeep on 36's must look ridiculously cool, but I imagine it would run like total crap.
My buddy runs 35's on an axle flip and 1" shackles in the read. Stock 2.5,gears and axles.. He is downsizing to 33's.. The ride, speed and "uselessness"(lol) of them is not worth the size.. But hey yall' enter "Jeep Lower Forty" on Google and check it out!! Since we are on the big tire idea..!!!
Works better with my 3 speed auto. I imagine on a 5 speed clutch it will be a little harder since autos stall up sort of creating a permanent feathering effect compared to a clutch... Unless its a lockup converter.
i have no problem with 33s on 3.73s.. i6 3-speed auto however.. even road in a jeep with same setup but with 35s.. never really had a power issue.. the 35s were a TAD sluggish for my ex.. but i had no problems.. i got my car to drive fast in.. my jeep is a cruiser :)
.....but that being said, stay away from SSR's and Thornbirds...they are the worst ones in the Interco lineup
I'm going to have to disagree with that. I've had 3 sets of SSRs to date and they are a great tire! On road the tighter spacing of the lugs make them a bit more livable, good compromise on tread compound so they last 30K-ish, on off road aired down they grab rocks like nobody's business.
Ofcourse they told you it would be fine, they will get more business out of you when it breaks and you find out the hard way it won't last and work properly....
Maybe you should take a look at what the weight is, for a 36" tire, compared to what your running now.
1 - 20 of 30 Posts
