1 - 20 of 27 Posts
I have a 33x12.5 on the stock carrier (for now) and i was wondering how to raise the 3rd brak light up? Also the tire shoves the 3rd brake light close to the windshield and my windshield wiper gets stuck. Any advice?
remove 3rd brakelight and get one that fits on center cap!
My 31" spare doesn't fit so I just bought one of these sets on eBay ($47) for both extending the spare tire mount and raising the third light. I assume it'll hold the tire out far enough to allow the wiper to move freely, too. We'll find out when it gets here.
Problem with those is (for 33s, 31 youl be fine) is it puts more weight out and will cause even more stress on the tailgate hinges. I really need to upgrade to some kentrol black ss onee but they arnt cheap.
Knows a couple things...
A 33" tire only requires the 3rd brake light sit up about 1" taller to clear it. You can easily take care of that with $1-2 worth of longer screws and three 1" spacers available at any hardware store. Remove one of the screws and match its thread size up at the hardware store with 1" longer versions which will likely be metric. They'll have 1" spacers too, that's all you need.
Personally, with all the drug and alcohol impaired or inattentive drivers on the road, I'm a strong believer in the 3rd brake light whether it is required by state law or not. Anything to help those inattentive/impaired drivers see my Jeep easier and that I'm on my brakes sooner is a good thing in my book.
- Myself and others have been carring oversize spares for years without tailgate issues (myself 5 years 33x12.5)
- All you need to do is make a few spacers out of anything (washers, pipe, tubing, wood) to rause it up. No big deal. When I had my thirs brake light, without raising it, my tire did not get in the way.
In my personal opinion, extenders like that are bad news. They help bigger tires clear of course but that they move the tire further away from the tailgate also give the heavier tire a significantly increased amount of leverage against the tailgate, its hinges, and the tub which will only create problems down the road. I never recommend anything like that for larger spare tires. If the spare won't fit as is, I recommend an aftermarket spare tire carrier.
And that you say your 31" spare won't fit is a mystery. The Rubicon comes with the metric equivalent to 31" tires from the factory and it uses the same spare tire mount your TJ has.
If you move the spare out, you NEED to keep the rubber bumpers tight against the tire (space them out also) The bouncing around without them making contact is also what damages the tailgate and stock carrier. Pushing it out puts even more leverage on the tailgate/carrier.
Stop it Jerry. You are too fast for me with the same points!
Thanks for the advice. The lack of fit was per the guys at the tire store...I'm not sure how much of a clearance problem there is. When the kit arrives I'll raise up the third light first and if the tire's still hitting the bumper I'll see if I can get away with longer screws/a few washers to minimize the extension, or look into a new mount altogether.
I did the third brake light in the center cap of my spare. LED from Oreillys and about thirty minutes and I was done. I put my center cap on a lathe and bored the hole that way but I'm sure a hole saw or a jigsaw with a steady hand will work just as well.
Discussion Starter · #15 ·
I did it this afternoon. It was a 2.5" 4 led from pilot. That and the 2 pin connector cost me 14$ and about 1 hr of my time.
The bolts on my third brake light bracket were long enough already. I loosen them, stuck a scrap piece of 1 X 4 board under the bracket and tighten it down. Added some hockey pucks to move the rubber snubbers out and called it a day.
KMG 365
For those of you in CA a third brake light is not required. CA consideres the third brake light as a supplemental light. I have not had mine on for 7 years. I did some reseach on this when I removed mine to make sure it was legal. On anoither forum someone asked CHP because they wanted to make sure what I found was right. CHP told them the same thing I did.
True, and I live in CA myself, but I go by what I said in my second paragraph in post #7 above... with all the drunk, drug-impaired, and simply inattentive drivers all around us, I like having that 3rd brake light. It simply gives those problem drivers a much more visible brake light to notice when I have put my brakes on. I personally strongly believe that 3rd brake light does reduce accidents and I prefer it being there whether or not it is legally required. :)
1 - 20 of 27 Posts
