Read Only
Just looking for people's opinion on weather or not a header is a worth while upgrade. If so what brand. Thanks for any input.
If you look at it from a cost vs reward stand point; it doesn't change much for performance.
This being said, there are going to be a lot of rebuttals to this. If your TJ is completely stock powertrain wise, you may see a potential gain of 1-2 MPG simply due to a better design in the exhaust flow. Power and torque wise, the measurable difference will be so small. Don't get me wrong, every little bit counts. But too many people purchase aftermarket items like this expecting WAY too much out of it. The 4.0L is designed very well and without power adders; it stays at its optimal range.
If you can find an affordable option, I say do it. Again, we TJ owners can use everything we can get our hands on when it comes to performance. There is also the exhaust note change. Sometimes that makes a fun difference just in the driving experience.
My two cents
Full Size Jeep Dr.
Any performance change is directly proportional to the weight of the money leaving your wallet.
Reactions: 1052145
Lots of prior threads and basically two opposite camps on this. Also, most of the offerings out there are junk and will crack eventually. Very few companies offer 304 CRES, 14 ga minimum thickness, welds on both sides, etc.
